JKBMS B2A20S20P w/Screen Connecting RS485 ?
I had the wrong one for the first try, also.
I didn't realize that there were different types.
Damn I hope you’re are right,. It will be here tomorrow and I will have it setup by the end of the day .. i been using the BT Monitor.. but that has to be close to the BT device so it is located in the compartment instead of inside .. and with summer coming I want to get it inside..
Power led should be on steady.
TXD and RXD should be blinking as data is transferred.
And you have the setup correctly in Solar Assistant?
This is the option .. looks right .. the other is the eg4 connector.. 1742517315830.png
And the JKBMS app does not show status .. but does get this data in the debug .. so it is answering .. just something wrong with format i guess.. This looks like three different packs of data.. Not sure what is wrong but it is across the board.. Can you check the wire colors for me? Yellow is A
[20:01:33,705] FF EC C0 98 07 FF 8E FE 8E FE 8E FF 8E FF 8E FF 87 FD 8E FF 8E FF 8E FF 87 FF 8E FF 8F FF 8E FC 8E FD 8E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 80
[20:01:33,706] 00 FF 8E 10 20 A0 40 5E 00 7F 40 7E 40 6E 00 5F 00 7F 40 BC 00 03 C2 01 EE 03 CC 01 FC 01 C0 01 C2 01 E0 01 FC 01 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40
[20:01:33,717] 40 80 80 00 FF 0F 08 68 90 81 00 FF FB 1A FC 1E 04 00 08 00 10 00 FA FC 6E 41 00 C0 3A 10 00 22 00 40 00 87 FF 0F 88 1F 10 00 20 4F 3F 07 14 30 08 00 10 00 20 00 40 00 80 00 00 00 00
[20:01:33,720] 00 FF 80 40 40 80 80 C6 10 20 20 22 00 40 FC 01 03 02 02 04 44 9E 04 04 08 28 10 50 20 A0 08 00 90 B4 0C 0B 00 00 00 00 20 40 40 80 80 00 F7 C0 9C 18 FD 21 27 00 40 00 C0 FC 00
[20:01:33,724] 00 00 00 00 00 00 00 00 00 00 01 FE FE 34
[20:01:33,735] 00 08 F8 10 20 20 C0 7E 10 22 06 02 18 44 F8 FF
[20:01:34,497] FF C8 83
[20:01:34,504] 90 86 FD 8E FC 8E FF 86 FF 8E FC 8E FF 47 7F 88 8E FF 8E FE 8E FF 8E FF 8E FE 8E FF 8E FE 8E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 80
[20:01:34,510] 00 FF 8E 00 90 C0 A0 6F 40 5E 40 5E 40 6E 00 5F 40 FF 80 38 00 78 00 78 00 7B 00 BD 00 BF 00 78 00 78 00 7C 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 40
[20:01:34,519] 00 80 00 00 FC 0F 00 28 24 81 00 3C FF 1E F8 1E 00 00 00 00 FF 3E 10 00 F0 3A 10 00 04 08 08 F0 C8 0F 80 1F 10 00 DF F4 1C 40 C0 20 00
[20:01:34,522] 00 00 00 00 00 00 00 00 00 00 FF 00 00 CE 10 20 A0 44 40 88 FC 01 03 02 00 00 C4 9A 00 00 01 00 01 02 0F 00 00 3E 89 BC 02 00 00 00 3F 01 00 00 00 00 FF 10 31 38 FC 21 66 00 80 FE 00 40 00 80 00 00 00 00 00
[20:01:34,528] 00 00 00 00 03 FE FE 14 08 08 F8 10 20 20 00 FF 00 E8 06
[20:01:34,540] 02 18 44 F0 FF
[20:01:35,308] FF C8 03
[20:01:35,313] 07 FE 86 FF 8E 8E FF 47 FE 47 FE 8E FE 47 FE 8E FE 8E FE 86 FF 8E FF 8E FF 8E FC 8E FF 8E FE 8E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 80
[20:01:35,320] 00 FF 8E 10 90 E0 80 7F 00 7E 40 6E 40 4E 40 BF 80 FE 00 78 00 78 00 78 00 79 00 79 00 7F 00 03 C2 03 E0 01 FE 03 02 02 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 01 00 00 00 00 FC 0F
[20:01:35,325] 00 E8 7F 20 20 CF FF 1A F8 1E 04 00 08 00 10 00 20 00 3F FE 6E 01 40 C0 3A 10 00 22 00 40 80 84 FE 0F 88 1F 00 00 50 E4 1C 40 E0 20 40 40 80 80 00 00 00 00 00 00 00 FF 80 40 40 80 80 C6 00 20 80 44 00
[20:01:35,331] 14 01 01 02 02 00 C4 9A 00 00 00 01 00 03 02 0F 00 00 3E 62 5E 81 80 00 00 00 20 01 00 00 F7 50 31 38 FC 21 46 40 00 00 FC 00 40 00 80 00 00 00 00 00 00 00 00 01 FE FE 14 00 08 F8 10 00 00 F8 00
[20:01:35,349] 44 06 02 18 40 F0 FF
Yeah I switched them and got no data .. the data is just wrong coming back from BMS .. wonder what brand it is.. make a fake BMS? May look around and see if I can find out what rs485 it is.. cause the JKBMS software don’t like it ..and SA don’t like it, but it IS responding to inquiries…
Looks like this has been a subject prior to now .. (and this is my version : hardware version V11A, software version V11.54. )
I tested today, on updating the device number within the app.. and it only responds to the correct device numbers.. So it has to be the older version of the RS485?
I am selecting from a very limited list in the options in UART Protocol "001 -JK BMS RS485 Modbus V1.0"
Is this the same thing you have selected?
Can you see what one was already selected? I assume it is the same, cause I don't think i changed mine .. but figured i better check everything at this point.
You will have to tell me where to look. I'm not seeing it, anywhere in the BMS app.
Hey thanks … the second tab on the app … the UART is the one I need .. click on it and I want to see the options , and the one selected..
