Solved in 15.30 and 15.32…not at all. Made worse…yes.Yes but in 15.30 and 15.32 a lot of other things seems solved so...
If I believe the video from Andy...15.30 or 32 is the best till now rightSolved in 15.30 and 15.32…not at all. Made worse…yes.
Seems some of the people in this forum are reverting as mentioned a few threads up. Andy is very specific with Victron integration. Doesn’t seem like they will ever fix the SOC drift and SOC charge trigger issue.If I believe the video from Andy...15.30 or 32 is the best till now right
Ill already have the m5 soc fixer solution ready to plug in, hoping this will help.Seems some of the people in this forum are reverting as mentioned a few threads up. Andy is very specific with Victron integration. Doesn’t seem like they will ever fix the SOC drift and SOC charge trigger issue.
I have a Solark 12K and I look forward to hearing some success stories.Ill already have the m5 soc fixer solution ready to plug in, hoping this will help.
Besides of that I have a Deye hybrid and was guessing to flash 15.32 this week.
Because with comms, it reports that back to the inverter, and the inverter adjusts charging based on that, I think.Why is it so important to get the SOC to be accurate? Don't a lot of these pre-built server rack batteries that don't even have screens not provide that info?
I'm not even clear how that works if you have 10 EG4 server rack batteries for instance how can it handle if one battery says 100% and another 95%? There has to be some fudging going on with those as well.Because with comms, it reports that back to the inverter, and the inverter adjusts charging based on that, I think.
what does "closed loop" mean? (sorry or it is my to direct Dutch translationI have a Solark 12K and I look forward to hearing some success stories.
I'm able to make my batteries work without closed loop with very little effort.
No, in 99% of the non-victron-with-shunt systems, we rely on the BMS reported SOCI'm of course assuming you have an external shunt to track the entire battery bank's SOC.
what does "closed loop" mean? (sorry or it is my to direct Dutch translation)
Communicatie tussen BMS en inverter, waarbij het BMS leidend is voor laden en ontladen..what does "closed loop" mean? (sorry or it is my to direct Dutch translation)
"closed loop" is when your BMS tells the inverter the battery state of charge.what does "closed loop" mean? (sorry or it is my to direct Dutch translation)
Actually it is a lot more than that, and it saves you equipment and is a safety feature"closed loop" is when your BMS tells the inverter the battery state of charge.
But we can tell the inverter to always charge to whatever voltage we want. And the BMS will stop the charging if anything goes wrong.
Closed loop is kind of slick but not necessary. I'll have closed loop someday but I don't care much when.
Can you elaborate on how it is a safety feature?Actually it is a lot more than that, and it saves you equipment and is a safety feature
I probably will use it someday. That's why I bought an inverter BMS.Actually it is a lot more than that, and it saves you equipment and is a safety feature
I only have Andy sourceAs of 08:45 EST 23.09.2024 the JK "official" software repo shown below.
BE CAUTIOUS With Patches & Versions coming from "who knows where" which is an "extreme" invitation for Murphy's Laws to be applied !
@Nami October is right around the corner. Andy versions don't count since they are not on your official web site. Are you going to be able to keep this promise for an updated version?This month
Judging from Andy video today.......and there is no mention of JK firmware at all.......I guess we got ghosted again?@Nami October is right around the corner. Andy versions don't count since they are not on your official web site. Are you going to be able to keep this promise for an updated version?
