Have you anything attached to the daisy chained RS485? ie something to sniff the network traffic. If something is interfering on the network then that can cause the issue you are describing? Might be worth checking your cables are pushed home. Have you put the master back to 0 on dip switches after updating and then the others 1,2,... etc?Hello, I have the same problem as you. The BMS constantly halves the charging current, I have already downgraded to 15.27, but the problem remains. I also noticed that I cannot use the parallel button in the PC software. Sorry for my Google English. Regards, Micha
Been there, got the t-shirt. A daemon was firing up and injecting traffic at the wrong baud rate on to the network intermittently.
