@AshleyL Top Marks for Bravery !
Hmmm 15:35 posted here, nowhere else, not a peep anywhere (yet).
Standing by to Read what people have to say.
The "Change Log" such as it is...
Just the 15:33 & 15:35 portions.
Current JKBMS Droid App
Published at 2024-11-24 Version 4.29.0 Build 38
极空BMS 5.0.1(Build 40) 最新版本 Android 版本 APK 下载。点击下载安装,尽享便捷电池管理!
www.pgyer.com
"JK BMS" APP is a management software for active balance series products.
play.google.com
* NOTE * The Incompatibility with sub-versions of Android is Back and it "may" not install from Google Play.
V15.33 Upgrade logs
1.Fixed a Bug with Victron inverter about energy consumption.
2.Fixed the bug of entering float charge.
3.Optimized the logic for SOC100% reset to Solve the bug that some inverters use SOC to control charging.
4.Fixed the bug where DRY2 failed.
5.Add one key to set Lion, LFP, LTO log recording.
@2024-11-04 by JKBMS
V15.35 Upgrade logs
1.Optimized ampere-hour integration algorithm to improve SOC accuracy.
2.Optimized SOC reset logic to 100%. After the absorption timer ends, if BATVOL > VOLSOC100%*CELLCOUNT , the SOC is set to 100%.
3.Added logic to enter float mode.
After the absorption timer ends, if BATVOL > VOLSOC100%*CELLCOUNT,
the BMS enters floating mode. Otherwise, the device enters bulk mode again.
4.Running parameters add the current charging status (Bulk, Absorption, Float), RCV Timer, RFV Timer display (mobile phone APP needs to be updated).
@2024-12-06 by JKBMS
