极空BMS 4.30.0(Build 39) Latest APK download for Android. 点击下载安装,尽享便捷电池管理!
www.pgyer.com
Just went to update to the new version and the old "Your Phone is Incompatible" nonsense is back again. This is beyond tedious already.
Well in any case, gonna update the fleet of V15 BMS to 15:38
Nice sunny Sunday in a Heatwave of -3C, the -20C and below are back Monday night so...
Gotta say, I'm hesitant to do all the packs... anxiety over such things should not be a factor... Great Job JK...
UPDATE 37 minutes later....
Pack, 1, 2 Went OK and got to 15:38. Pack 3 Gosh Golly FDarn, BRICKED at 51% and is as dead as a post non-responsive... Won't even power off.
The next three are on a shelf, and would have to be pulled out to open the covers to disconnect the BMS from Power to reset it...
As Fred Flinstone is known for saying:
Ruckus Stuckus Frickus Fruckus ! stomp stomp stomp
Update an hour later....
Pop the case cover, pull the power wire and play the Reset Button Powerswitch combo and 4 attempts and got back to 15:30 - Phew... Was I smart & quite there ? Hell NO ! Let's try 15:38 again... Got to 99% and Bricked again ! (Air got a bit more blue !!!) Teh plug, reset & powrswitch dance once again and after 6 more attempts finally got 15:30 back in and WORKING so THWT ! Buttoned the damned thing up and brought the lappie etc back in from the powerhouse.
Time to Puff a Doobie, Pet the Cat & Watch a good comedy ! Geez Louise !
DID GLEEN A LESSON !
If an update to BMS fails, then no repeat attempt will work
IF you do not restart the PC-App.
something in it's code glitches and keeps the error.
1) Restart PC-App and get it set to proper COM# Port, Don;t "CONNECT YET"
2) START the BMS from an
OFF State and WHILE HOLDING POWER SWITCH, connect the PC-App, Select the Update, the file, force update & PASTE in the CODE, continue with update till 100% & BEEPS
THEN LET GO OF POWER BUTTON !!!! Gotta hold the Effin thing all through the update process. That is the ONLY combo that works, and I tried the variations not only THIS time, had to go back to my notes.
PS: I am using the Official JKBMS USB -> RJ45 dongle/cable assembly.
