You are overdriving the cells a bit - the Working Voltage is 3.000-3.400 and LFP will "always" settle due to the chemistry and is normal & expected. Adjust the values down "Just a bit" and you will be rewarded with well balanced fully charged & saturated cells within each pack.
All my packs reach 100% by the time Absorb transitions to Float and within 15-20 Minutes of entering float, All Cells in All Packs are within 0.005mv of each other across the bank (6 packs in parallel).
Solar Controller Notes:
ABSORB is set to 27.8V / 55.6V (3.475 vpc) for a Max of 1 Hour.
- rtpically only runs 30 Minutes before EndAmps is reached, at which point it transitions to Float.
FLOAT is set to 27.7 / 55.4V (3.4625 vpc)
- Trickles in for balancing till BMS' go into REST Mode as Float can service ongoing loads while solar is sufficient.
ENDAMPS/TAILCURRENT for 280AH Packs = 14A. This is calculated as 100AH X 0.05 = 5A or 280AH X 0.05 = 14A
- Use the largest pack in a bank for calculating the EndAmps/TailCurrent.
Settings from the PC-APP. The BMS' are all V15 Hardware 200A models with 2A Active Balancing.
Balancing NOTE: Do not start too early, it is self-defeating. Once the 1st cell hits 3.42 it begins to balance out the cells and keeping the cells within the spec'd range.
* My bank has V1 (2018) through to V3 (2024) Cells in the packs (All EVE LF-280) and a mix of Bulk, B and A Grade cells and this works across ALL of them. It also worked with my previous setup with 1x105AH, 2x175AH, 3x280AH in one Parallel Bank.
