HarveyDent
2.9 or 2.8 ??PC-APP 2.9 Works reasonably
Where can I download version 2.9?
Exactly. Let's use pace BMS. Passive dissipative balancers are superior. Pace communication is solid too. Why waste our time with these jk BMS. I don't think I've ever used one before.Pacebms ( sok, jakiper)
Seplos
Both have good comms, but passive balancing.
Due to victron's way of implementing comms and seperated chargers and inverters may require specific setting
Both solid as a rock
I prefer seplos..Exactly. Let's use pace BMS. Passive dissipative balancers are superior. Pace communication is solid too. Why waste our time with these jk BMS. I don't think I've ever used one before.
What's the voltage differential before and after, and are you using the same cells as before?Actually the active balancer has been rather impressive. The older model JK has kept my battery in better balance than my Overkill batteries.
Except initial (extra) top balanceIf you have good cells the active balancer should never be triggered.
I don't know if you've been keeping track but many owners of the eg4 lifepower4s struggle with battery balance issues. Which could prob be easily resolved if they had active balancing.If you have good cells the active balancer should never be triggered.
Or the BMS setup correctlyI don't know if you've been keeping track but many owners of the eg4 lifepower4s struggle with battery balance issues. Which could prob be easily resolved if they had active balancing.
Apparently it's all workarounds due to Narata BMS limitations.Or the BMS setup correctly
Then maybe switch to a proper BMS ?Apparently it's all workarounds due to Narata BMS limitations.
No, that's a problem with the cells. Even a 104kWh Tesla pack uses small passive dissipative balancers. Active balancers are completely unnecessary and that's a fact. And just the design of the circuit increases susceptibility of fault over time. There's no benefit of that added complexity.I don't know if you've been keeping track but many owners of the eg4 lifepower4s struggle with battery balance issues. Which could prob be easily resolved if they had active balancing.
Or seplos..I'm glad Steve started this thread and is documenting all of these faults. Same with Andy from off-grid garage. And they're not responding to anybody. Or fixing said issues. They are not located in America so they don't seem to really care what we have to say.
I think we should get in contact with Pace BMS and see if they can make a model with more features.
We need some solutions now. We know what the problem is and we have proven it. What other solutions do you guys have?
Except that is really hard to consistently "purchase". He closed the "store" again and parts are frequently not in stock if you try to have them built yourself.Or maybe even better..
Contact Stewart pittaway of diybms..
His hardware and software design is completely opensource, and from what I read and have seen works extremely well
And that's why , he ( and others wanting to use his stuff) orders in small quantities..Except that is really hard to consistently "purchase". He closed the "store" again and parts are frequently not in stock if you try to have them built yourself.
The lifepower4 or the LL v.2 or both?No, that's a problem with the cells. Even a 104kWh Tesla pack uses small passive dissipative balancers. Active balancers are completely unnecessary and that's a fact. And just the design of the circuit increases susceptibility of fault over time. There's no benefit of that added complexity.
Maybe that's why signature solar is having another company build that pack now. I just learned of that last week.
Lifepower4 is being made by same company that makes the LLThe lifepower4 or the LL v.2 or both?
So they've changed the cell supplier to get better consistency/quality? I guess it'll be a silent running change and not a lifepower v2 type revision.Lifepower4 is being made by same company that makes the LL
Narada I gather...Lifepower4 is being made by same company that makes the LL
