Hey there, I am using a JKBMS with my solar installation and a 5kWh LFP battery plus a Raspi to make it all work as intended. Works good.
For another different project, I will make use of another JKBMS and another battery pack.
The thing with JK is, that you need the App to turn discharge on and off. I would rather have an external switch that does this job: turn it on and the BMS switches discharge ON, turn the switch off will let the BMS stop discharging. Instead of having to fumble around with the app all the time.
I thought about using a ESP32 using RS485 connection to do this. I have found some code samples and a lot of posts having trouble communicating with the JKBMS. Maybe someone has done exactly this before and I just havent found it yet?
Or my approach isn't the way to do this?
Any comment is welcome!
Thank you in advance.
