Microbiologycory@gmail
Hey guys,
I know this might seem a little odd but my EG4 48V-100Ah battery seems like it always needs charging (battery is 100Ah but BMS restricts discharging to 10% and charging to 90%, yielding an 80Ah battery) so I’m considering a solar panel for my EV-Gator either in the bed/on the roof or both to top it off when I’m not using it (my bed is 44x45” inside), the roof and s a less good option as I live on the side of a hill and it’s common to have 30-40mph gusts. After doing a little research I’m going to need a “boost” solar charge controller, but the problem is that they are all under powered for the panels. Renogy, Eco-Worthy, solarevsystems.com and others make these but they range between 8-12Amps before they blow a fuse and the 20x40” panels are usually 100-150 watt and 15 Amps each, would either put both in the bed (the dump-bed tilt would help keep it facing the sun). Even if I ran two boost controllers (1 for each panel), I’d have to lay a towel over them to keep the panels from receiving 100% light transmission, so am I overthinking this with the inefficiency of panels, the decreased power in heat (I’m in central Texas), etc.. Also, if used in bed, would a thin layer of Lexan/plexiglass kill the efficiency of the panel, or maybe just lower it to the right level for the 12Amp boost controllers. If there is any way I could get around a boost controller I’d love to as all the other MPPT controllers are much nicer and have more options, BT apps, etc. though I do have the Renogy shunt 500Amp energy monitor.
Here are some of the items I’m considering:
Thanks for any help you can give.
