i had posted something similiar earlier but now that i have the exact battery,,, my usage is i put the 12v battery behind the drivers seat and hook my 12v cooler directly up to it. usually lasts me a few days. can i hook up a charging cord straight from the alternator ( toyota prius 2012) or i could plug in a small inverter in the 12v accessory port and use a real charger? in my 4runner, i have a inverter 115v plug that may work.
i already have a battery tender that i can set to lithium, will that work to charge it while i am driving?
although, i hooked it up to the lithium soria battery i have in my atv and i think it ruined it, not sure what happened yet
Battery Tender® 6V/12V, 4 Amp Lead Acid & Lithium Selectable Battery Charger
12V or 6V switchable @ 4 AmpSelectable for AGM/Standard/GEL or Lithium (LiFePO4) *12V only for LithiumISM™ (Infinite Sequential Monitoring) of the fully automatic 4-step charge process (qualification, bulk charge, absorption, float)Microprocessor controlledSpark proof even when output leads...
www.batterytender.com
