Just found out my Daly BMS is not working properly
  • Thread starter Deleted member 9967
  • Start date
D
Deleted member 9967
Guest
So I was charging my cells and number 5 [of 8 cells total] and the Daly BMS kept saying it was 0.2 volts higher than all of the rest of the cells.
I tested it with my multi meter and it was fine.
Ok so after a few hours my Juntek coulomb meter said everything was charged to 95% and so I stopped the charging.
Cell 5 was at 3.6** according to the BMS but not according to my multi meter.
After letting everything rest for about 4 hours I checked the voltages of all 8 cells. Every single cell read the same.
3.33 volts.
But the Daly BMS had said something different.
So for whatever reason, the Daly BMS is stating that cell 5 is off.
Not looking for solutions as I don't think there are any.
Mostly just a heads up to others to always double check anomalies with a multi meter.
Hope this helps someone out. :)
