kalabaddon
- Apr 19, 2022
- 4
Hello all!
Here is my setup. The cables going out to left are to the car battery, The top smaller not connected cables are showing where the solar will connect to. I am using a briefcase 200 watt setup with some xt90s connectors I put on it.
Everything is 2 awg cept the solar cables and cables going to fuse box which are 8awg.
I got a friend that will assist me with everything on it this weekend, but he deals with City power so mostly high voltage stuff, not 12 v battery systems. So I wanted to get some input first.
The fuse box will have these connected to it. I will be cutting the cables shorter and removing the inline fuses and just fusing from the fuse box.
I also haven't connected the tiny positive shunt wire, or the bt and temp module for the charger.
My understanding with the IOTA is that as it is with out that loop back it will charge at 13.6 which will get the battery most of the way topped off, I have the lifepo4 iq module coming, but read some mixed info about it potentially overcharging since it will go to 14.7 before it tapers off.
Anyways, how does this all look to you all? any glaring issues you see?
