adventuretrimarans
- Jul 16, 2021
- 5
Hi Everyone.
New to all this and pretty excited as this unit will be a great help camping and using various tools when working on my cars/boats away from my workshop.
Anyway, unboxed and connected up my first 200w Dokio and getting 158-160 watts straight away. Great. It is an unusually nice day here in the UK so I was always banking on putting both 200w panels in series.
I've got cabling sorted to test the 2 panels in series on Sunday as away sailing for a couple of days now but in the meantime I'm trying to find out about other charging options.
Looking at the 240V AC power brick that comes with it I'm getting 215watts at 42V and the EB150 can take up to 500w I believe.
So when I'm driving along in the van I want to be able to charge and have a 300w pure sine wave inverter so I can just plug the brick into that in with no problems I think?
Separately I have had this charger for some time: https://uk.rs-online.com/web/p/car-chargers/6796710 which can be set to output 24v @ 5amps which would fall squarely in the volt/amp range for the DC input the EB150 can use?
It doesn't come with the 8m tip but there is a plug tip that fits the 8mm tip that comes with the Dokio so it seems good to go.
However, I thought I would drop Bluetti support a quick note and about half a dozen emails later they are saying:
"as the internal hardware of the product does not support car chargers, this is due to the product itself.
You may try to do so, but we cannot guarantee the results of your connection, so we do not recommend that you do so."
So I have kept asking them how/why/if either pure sine wave inverter plus brick could cause any issue with the EB150 and this is the answer I keep getting.
Is there any possible way that using either the straight dc-dc boost charger or the pure sine wave inverter could cause any issues?
I can't see how or why but I would be grateful if anyone could enlighten me!
Also, if both methods are equally going to cause no problem, which is likely to be the most efficient way of doing it?
The dc-dc charger is much smaller and more compact and has no fan running making more noise so that would be great, but either is perfectly acceptable in reality.
Thanks for any help/insight that can be offered!
I've got lots of things to learn and understand related to this and I'm also going off to electric outboards and ebikes.
I've got a 48V 30Ah 2800 watt battery with 70 amp BMS ready for my 2800w electric outboard that arrives next week. I'm going to make a nice battery carry case to fit in the frame of my bike for the the Bafang M600 (500w) unit on order and the battery will be used both on my bike and the trimaran so we will really get max use out of it.
I'm thinking then the boat/bike battery could potentially be used as a fantastic additional back up for the EB150 potentially as well as it only weighs around 8kg before the case and will only be about 27x25x8cm so tiny compared to the EB150.
As I said, very excited about all of this and look forward to hearing from some of you!
