Bud Martin
Photon Sorcerer
- Aug 27, 2020
- 3,216
That is great! I am going to order another set from BASEN after CN new year is over. Right now the price has gone up a little bit, not sure if it will fall in the futire or not.
Please post a link to that case.A trail fit of my 2P4S battery for 12vdc 564 AHView attachment 34541View attachment 34542
That seems to suggest they are 280ah cells? I assume you have some other plan for moving this 100lb case around other than the flimsy handle on the top?A trail fit of my 2P4S battery for 12vdc 564 AH
I got it from local lowes. but found it onlinePlease post a link to that case.
I'm covetous.
nice, that thing look heavy![]()
Curious: Are they cells being compressed left to right in this case? Reading this document (p.8) I was left with the impression that it is pretty important but, I'm still VERY much in the learning stage here.A trail fit of my 2P4S battery for 12vdc 564 AHView attachment 34541View attachment 34542
it will be permanently mounted to the floor of my RV. so it will be fine...The box has a 66 pound load capacity. It could be underrated and lifting by the ends will probably be fine. If moving it around often I would add plywood to the bottom to reinforce it. Just be careful the case doesn't start to flex which will put stress on the cells terminals.
I will be at very low C rates (like .1c) and very few deep cycles. I don't believe as important.. also not going to build a fancy apparatus either.Curious: Are they cells being compressed left to right in this case? Reading this document (p.8) I was left with the impression that it is pretty important but, I'm still VERY much in the learning stage here.
By the way i just started this ideal in Oct. and ordered batteries Nov 21 so I am so learning alsoCurious: Are they cells being compressed left to right in this case? Reading this document (p.8) I was left with the impression that it is pretty important but, I'm still VERY much in the learning stage here.
I believe you but, I've not a clue as to what this means! lol. Actually, deep cycles I kinda' get but, C rates I've not formed a comprehension of yet. I see them talked about here and there but, have yet to see them relating to anything I'm doing.... that I know of!I will be at very low C rates (like .1c) and very few deep cycles.
C rates is the current (amps) of charge-discharge.I believe you but, I've not a clue as to what this means! lol. Actually, deep cycles I kinda' get but, C rates I've not formed a comprehension of yet. I see them talked about here and there but, have yet to see them relating to anything I'm doing.... that I know of!
I have been charging my EVE cells with a 12 amp charger and they do expand. They also deflate when discharging with an average load of 15 amps. Mounting the cells in a fixture has been more than covered so I will pass on that. However since your cells will be in a mobile environment it's most important to prevent stress on the cell terminals.I will be at very low C rates (like .1c) and very few deep cycles. I don't believe as important.. also not going to build a fancy apparatus either.
I do plan an using the box to provide some.. i am thinking I will put aluminum plates on each end of the battery then spray foam and it will apply some force...
I am also going to use some VHB tape between the cells to help with vibration and prevent rubbing
To calculate the C rate you simply take the load or charge current and divide it by the capacity of the battery.I believe you but, I've not a clue as to what this means! lol. Actually, deep cycles I kinda' get but, C rates I've not formed a comprehension of yet. I see them talked about here and there but, have yet to see them relating to anything I'm doing.... that I know of!
Awesome. Thank you!To calculate the C rate you simply take the load or charge current and divide it by the capacity of the battery.
For example I am charging with 12 amps. 12 amps divided by 280 is equal to .04 C rate.
The manufacturers list the maximum and standard C rates in their cells specifications. My 280 amp hour EVE cells are capable of maximum 280 amp 1C rates. That means it will take 1 hour to draw the full 280 amps using a 280 amp load. Or 1 hour to charge with a 280 amp charger. However EVE suggests the standard C rates are .5 C or 140 amps.
The C is short for Coulomb. A coulomb is defined as a unit of electric charge.
7.74US $ 10% OFF|Dykb Smart Bms 4s 12v 60a 80a 100a 120a Li-ion Lifepo4 Lithium Protection Board Balance High Current Bluetooth App Software Gprs - Battery Accessories & Charger Accessories - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
