I've got my beast working, but for the Inverter (Amazon lost my 8 AWG 5/16" ring terminals... argh).
Here's a weird thing. I had plugged my AC Charger into the Rich Solar input overnight, set at 32V. When I turned it on, it dropped to about the battery nominal voltage, but was pushing 11.x amps into the batteries. Great!
When I woke up this morning, the batteries were at 14v, the AC Charger was back at 32V, and the battery pack was not charging.
I went out and plugged in the solar instead of the AC Charger, and same thing -- no more power was going into the batteries, despite full sun and the PV input showing upwards of 38V.
The Rich Solar PWM Controller is set to Sealed based on the
sticky post from Will on ideal BMS settings for 12v systems (Absorption: 14.5V (14.4V for sealed), Float: 13.6v). There is no load on the batteries currently.
Is this expected or weird? At what point would the individual cells get charged above 3.5V each (max charge is 3.65V). I have a 12v 4S 60A Daly BMS managing the 4 LifePo4 cells.
