For the units I have the manuals for, yes. You can program almost everything. HVD LVD charging amps, float voltages and so on.Is the charging profile suitable for lfp or programmable on the mppsolar?
24 volt 2000 watts? Do you have a retailers link where I can look at it? Thanks.There is a 24V version (but only 30A): http://www.kisaepower.com/wp-conten...nual_DMT12V_24V-Series_Rev-D_190612_Print.pdf
I can't do solar because I live in an apartment. So I don't know. Sorry but I haven't studied up much on that end of things.What is the difference between one of these and a standard MPPT charge controller such as those fold by Epever?
Isn't that a DC to DC battery charger with solar input? I was asking about the Kisae 24 volt inverter charger.....lol.KISAE DMT2430 Abso 30A, 24V DC-DC Battery Charger | DonRowe.com
KISAE DMT2430 Abso 30A, 24V DC-DC Battery Charger is a multi-stage, multi-input battery charger capable of charging different types of batteries commonly installed in boats, RV's, 4WD's and commercial vehicles.www.donrowe.com
$350...
I must be missing something because these seem pricey for what they do - what is the attraction? (unless you have an alternator; I get that part of the equation).
Look at post #74 (which you responded to).Isn't that a DC to DC battery charger with solar input? I was asking about the Kisae 24 volt inverter charger.....lol.
This one looks promising , I just need a shipping quote.I tried the MPPSolar link and for 24V I only found a 2400W unit, I am looking for a 3000W unit.
Something is really weird with that ad....the title says 12v-24v-48vdc to AC, however, the description is altogether different. In two places it shows the same 230VAC input. The picture shows the input is from a bank of solar panels. I was expecting it to show 24VDC battery bank as input, 120V output.This one looks promising , I just need a shipping quote.
PRICE(EXW)Sample
$324.03 3500w
$398.91 5500w
WIFIMonitoringModulePRICE(EXW)
MQO>10
$35.66
INPUT | |
Voltage | 230 VAC |
Yes there adds and sales info is not totally up to date, I got this on the first contact.Something is really weird with that ad....the title says 12v-24v-48vdc to AC, however, the description is altogether different. In two places it shows the same 230VAC input. The picture shows the input is from a bank of solar panels. I was expecting it to show 24VDC battery bank as input, 120V output.
INPUT Voltage 230 VAC
"SCI02-PLUS Product features as below:
* 3500W model PV Max Power has been upgraded to 5000W, 5500W model PV Max Power has been upgraded to 6000W. Max charge current
has been upgraded to 100A. MPPT range operating voltage has been upgraded to 120-500V.
* It can be running without batteries at daytime, energy shared from utility and solar to loads at the same time or alternatively.
* It combines a wide PV input range MPPT controller, can convert solar energy from PV to loads directly and the remainingsolar energy will be
converted to batteries at the same time.
* When PV output is reduced by clouds or at night, resulting in no surplus PV power avaiable, loads powered by utility, batteries are charged,
when utility outage, batteries are discharged.
* Has GPRS or Wifi monitoring System remote control.
* Can charge LiFePO4 battery.
* We have 500pcs in stock, 1-2 days fast lead time after payment received."
As for the shipping it is some of the lowest I have seen so far.
If you buy 1unit 3500W or 1unit 5500W, shipping cost to USA is USD160 by DHL.
If you buy 2units, shipping cost to USA is USD237"
Description of solar inverter:Now I am more confused as I thought we were talking about an inverter to convert 24VDC battery voltage to 120VAC. The ad and your description sounds like a solar charge controller?
As of now it looks like I will be going 24V. The solar panels are small. I have a contiguous space on the roof that is 3X13'. So I researched panels that were 3' in one dimension to get as much space utilization as possible. The panels are 36X26" which will exactly fill the space. These particular panels are 33 cell. I am not understanding the relationship between the BMS and the solar panels?I would go 24-volt system for sure. it sounds like you need to make a decision on the charge controller. charge controllers are based on amperage and watts. you can upgrade later if your charge controller has room to add more solar panels. the DRRR20's will work as a solar charge controller if your panels are 30 or 36 cells? or you can choose an MPPT solar charge controller. the Electodacus SBMS0 can control them also.
the 100 watt panels are pretty small 600watt total but could charge the 8 Lishen 272Ah cells.
12 volt requires larger cables to the inverter as it draws a higher amperage.
24 volt is better in my opinion.....
The Samlex EVO-1224F is only 1200W and costs more than the 3000W Giandel I am looking at. The Giandel is $432 and is made in Australia and has the Will Prowse stamp of approvalThere are several different directions you could go with. Samlex makes good inverter/chargers...right up there with Victron IMO. The Samlex is a LF inverter which means it can deal with surges better than HF inverters and as far as I know better than the Victron.
You could also look at complete all in one solutions such as MPP Solar and Growatt. They all allow the user to program HVD and LVD's. Since it's advisable to stay within the knees of the battery I am looking for something I can program.
Then there is the mid range such as Aims and Sigineer inverters. Programming is limited on those but they are good inverters.
I have never owned any of these so I am just passing one what I have read about them by researching and reading the spec sheets. And what other users recommend. There is no one size fits all solutions. But very important to keep in mind is what type of support does one receive in the event of a failure, whether within the warranty period or not.
I have been struggling deciding on an inverter/charger. I will be using it for a UPS in my apartment. I am leaning towards the Samlex EVO-1224F. The only thing I don't like about it is one needs to purchase the remote display in order to be able to program it.
I have even considered Ampinvt inverters. But I am hesitant to buy one simply because there isn't much known about them and I don't know how well they support them. The company that makes them is Top One Power and I contacted them directly on Alibaba. The translation from the other side was getting to me...lol. I also contacted Ampinvt and communication was better and I think support would be better since they are shipped from the USA. But I am still hesitant.
I can't even figure out non-hybrid Either way, I can't seriously consider a product whose own ad is screwed up. I am not just talking about an English issue, I am talking about spec's that seem totally haywire. From what I can fathom, the product is more oriented towards an on-grid application considering batteries are optional vs. batteries being the main source of power for the inverter. Are you saying the product works as a solar charge controller, power inverter, and as an ATS all in one?Description of solar inverter:
The AN-SCI02-PLUS series is perfect for off-grid,and self-consumption applications, it is a pure sine wave, hybrid inverter system,providing power from solar modules and utility or generators,no need batteries.It is able to prioritize solar consumption over the grid and works with the grid to avoid peak utility charges and support the grid when utility supply is limited.
I think it is great that it can work with PV and alternator, but there doesn't seem to be a provision from when you have shore power.I think it was me who mentioned the kisae charger. If it’s a vehicle based system your building then there great. If it’s apartment based then not worth the money I would guess
It costs more because it is UL listed, is an Inverter/Charger with a transfer switch built in, and it's made by SamlexThe Samlex EVO-1224F is only 1200W and costs more than the 3000W Giandel I am looking at. The Giandel is $432 and is made in Australia and has the Will Prowse stamp of approval
I suggest going 24-volt battery build and get a 24volt inverter. if you need any 12-volt stuff just ger a converter to transform the 24 volts to 12 volts.I actually need all the same stuff as you and i'm in the same boat. I am looking at getting one of these all in one units so I can use in the RV or cargo/hunting trailer or as a backup power for grid down power outages with the California fire situation in the past few years.
https://www.alibaba.com/product-det...offerlist.normal_offer.d_title.437e290cDx5zrd
I can move this and the batteries to any location pretty easy.
try to find 60 or 72 cell panels; I do not know about 33 cell panels; you might go to electrodacus.com and ask this question to Dacian the owner engineer of Electrodacus. my 60 cell 250-watt panels are 39 x 65 inches each. I put the in pairs of 2 and this works great. the newer 72 cell panels have more watts so you may want to get the higher wattage 72 cell panels. I bought 2 pallets of used 60 cell panels for cheap on eBay.As of now it looks like I will be going 24V. The solar panels are small. I have a contiguous space on the roof that is 3X13'. So I researched panels that were 3' in one dimension to get as much space utilization as possible. The panels are 36X26" which will exactly fill the space. These particular panels are 33 cell. I am not understanding the relationship between the BMS and the solar panels?
I have additional space on the roof for probably adding another 4 or more panels but intend to start with 6 panels. I will be building an aluminum frame that will be bolted to the roof trusses so I will have a stronger connection and less holes in the roof. The factory 8ga wiring connector is right under where the 6 panels will be located. If I try to get sophisticated, I will set up the aluminum frame to be tiltable. Trying to source some actuators or servos that can be setup to tilt the panels.
Thanks!
