Cool, thank you!
Bri, thats what I was hoping. No dishwasher and the Dryer I was considering running a generator when forced to use it. We already have a line outside, but Iowa winters can be less than fun when the clothes need dried. Like I said I think a lot of it will be learning the limits and then living within those limits, OR expanding if the limits are too strict. What do you think of your Sol-Ark inverter? I was looking at the Sol-Ark and the SunGold Inverters... Also, SunPower panels are the most efficient, but it seems their customer service is non existent? So LG panels instead? What are you all using for your equipment?
I've been very happy with the Sol-Ark 12k, and I'm not familiar with the other brands you listed. My main criteria was UL listed and rated for series-connected panels. It supports up to 500VDC of panels in series, 4 strings total. I'm using 9 panels in 3 strings, could have been 10 or 11 panels. My open circuit voltage is in the 350VDC range, but a person also needs to be aware of the -30F panel open-circuit voltage phenomena, so I'm well below that. Higher voltage means smaller wiring... I used #10AWG, but it needs to be PV wire, special for higher voltage DC. Don't use THHN or THWN-2, i.e. common building wire for the solar panel wiring.
The Sol-Ark has cloud interface, which isn't required if you don't want it, but is nice store a crazy amount of historical data and be able to access with phone/computer to check on things. I can't change settings remotely, but can see what's happening. I've also had a trip/error once, and Sol-Ark contacted me about it... impressive. If I ever feel like big-brother is watching too closely, I'll pull the WIFI interface, and run in dark-ops mode.
My panels are Mission Solar. got them from PowerStore in (Houston?) Texas anyway. They are made in USA, but that might be just final assembly, not the whole ball of wax. I wouldn't pay extra for "efficient" panels, unless you are space-limited, and I generally agree with the lowest $/watt. But keep an eye on the frame dimensions and thickness so they remain rigid. I have a ground-mounted rack system of my own creation, and it was quite expensive, a little more than the panels if I recall. You'll want to plan ahead for that. I didn't have a good roof to do it, and several local installers encouraged me to build a dedicated building with a roof that angled south. My terrain and house location didn't permit that, but it would have been close in cost if my terrain worked... and I would have had a nice shed for acreage toys. Maybe next time.
I have 27 panels at 320watts each, for a total of 8,640W. On some days when they were new, I'd get 9,500-10,000 watts at times (in winter with snow on the ground). This summer, with hotter temps and dirty glass, I'd peak out around 7,500 watts, so I'm curious how they will perform in this next winter. Time will tell if I add more panels or not. I'm in a year-long learning mode for now.
My battery is custom DIY, bought them from Michael Caro in the group buy section, took about 3 months. Shipping was slow and with log-jams at Long Beach then, and I think it might be worse now. I recommend him: didn't know him at all, but it worked out great... saved a bunch of money. 272AH cells, 80 of them. I have two strings. One string is 3P16S, the other is 2P16S, for a grand total of 1360AH. Each string is protected with Class T fuse, don't use the ANL style. The Class T fuse is rated to interupt large short-circuit DC currents. I used 2/0 welding cable from the battery to the Sol-Ark, but if I did it over, I'd use 4/0. When the battery charge/discharge is high, i.e. 100amps or more, I get notable voltage drop, about 0.5V or so. But it just annoys my psyche, doesn't seem to affect anything.
For the battery, I got a JK active balancer and a JBD (aka Overkill Solar) BMS/protection, one pair for each string. The balancer and BMS are both bluetooth, so I can get close with my phone and check into them. The BMS's are wired to a "Electric Car Parts" DC power relay, 200A, to disconnect the battery if there's a battery cell that's too high/low voltage or too cold.
The battery can get me through about 3 days of care-free power useage during full clouds. Keep in mind that full overcast, can still eak out some (roughly 10%) solar generation, but is highly dependent on how thick the clouds are. If I cut back usage to just essentials, I could probably get about a week without sun.
I still have utility power, and have re-wired my house to be split into 4 different interlocked panels, which I can individually put on solar or on utilty. During winter all geothermal will be on utility, unless an emergency. If it were just a LP gas furnace, that could be on solar, but geothermal is too much for my system. I don't have a generator to charge the battery.
