Hello, we finally came online this morning! It's been since last August until now, mid-April. But we've learned alot, haven't died nor burnt our house down. We have 3 series running, but only 1 seems to be producing. Any advice on where to start the troubleshooting? see attached image.
@G00SE , PV 1 & 2 face East on pitched roof. PV3 faces West on back side of the pitched roof. PV 1 is series of 10 panels, PV 2 is a series of 8 and PV 3 is a series of 10.
[TXI10-400108BB-N] Mission Solar 400W 10BB Half-Cell Black Monocrystalline PERC PV Panel - Odoo.pdf
I found another thread of yours with panel specs.
Input into the Midnite string calculator (I picked temps of -10 Celsius to 65 Celsius as it’s never been 15 degrees F in the 30yrs I was in phx so it leaves a bit of cushion)
This is for 10 panels in series, which should be no issue on any of the inputs. 8, even more of a buffer.
So it would seem apparent all panel strings are well within specs for the inverter, I would start looking at connections one by one and see if there’s any issues on string one and three
Looks like you’ve got a solid foundation of equipment. Hopefully it’s something trivial. String 1 should be getting the same sun as 2 so the fact it’s at 0 makes me thing there’s a wire issue somewhere
Hello! I need some guidance as I'm new to solar setups. I have ten 6V 250Ah batteries from a Moke electric car, which I replaced with lithium ones. I want to use these batteries to build a solar setup because we frequently lose power in Georgia. I'm looking for advice on the best setup. Should I string them to 48V, although it might mean losing some batteries, or should I run them at 12V in series and parallel to maximize the amp-hours?
