Noob from Kenya. Just installed a 1.3kw (4x 330w jinko panels wired for 42v) solar array, 2kw/60A/24v/mppt all in one Chinese inverter(xindun LS2024) and 4x 12V 200AHAGM Lead wired 24v. 8ft from panels to inverter.
Seem to have an issue with the charge control. At around midday (full sun no clouds) it seems to give a high voltage (41v) with no amps for a few mins and then return to a slightly lower voltage (33) with decent amps (32). Is this normal? Might it be a wiring or controller issue or something else?
