Hi Everyone,
I have an older variable voltage / variable current HP power supply I was using to top balance some batteries. With the power supply off, I was removing the leads and dropped one to the chassis of my RV while the other was still attached. a 1200AH LiFePo4 pack drew current through the power supply and started arcing against the chassis. I quickly pulled the wire away from the ground but it was too late.
Now, when I turn on the power supply it goes in to a dead short immediately. The current is still controlled from the front panel and as I increase it, the power supply draws a larger AC load and reflects the current increase on the meter. The voltage however stays at zero.
I opened it up and tested final power transistors and believe they are OK. I'm not an electrical engineer and really don't know how to diagnose this. I did discover that by disconnecting the base of A4Q102, the power supply powered up without any output at all. Better than being in a dead-short state I suppose.
Can anyone with power supply knowledge have a look at the schematic on page 83 of this manual and maybe offer some direction? I can do a lot of things but I know when I'm out of my league. This is one of those times.
Thanks for any help anyone can offer!
Scott
Scott
