Ceefiveceefive
- Sep 28, 2019
- 93
Greetings.
I made a mistake in wiring my LiFePo batteries to my system and am wondering if my batteries are salvageable.
I have two 48V, 289Ah LiFePo batteries in my system. I had been using only one battery at a time, switching between them. Both worked well for my needs.
I am installing a minisplit to my Homestead & wanted to up the amps of my system by putting both batteries in parallel.
The batteries use Anderson connectors. The way the individual cables were orientated, they were opposite one another.
I accidentally wired them to my MPP 6048 Hybrid inverter in series instead of parallel. The system turned on, then clicked off not turning on again.
I suspect I fried the BMS or some cells in my batteries, but I'm not sure as I have not taken them apart yet.
We measure close to 50V on both batteries, but they will not turn on my inverter (or a new substitute inverter we tried troubleshooting with).
Dies anyone have advice on what to look for that could be causing my battery troubles?
