Simi 60
- Jul 10, 2021
- 159
I haven't seen lanolin discussed here as protection for freshly cleaned alloy terminals
I could pay $25 for a tiny tube of ox gard or, as I already have 5 litres of Lanox MX4 on board could I not use that?
It sounds to me that it will do the same
Thoughts?
We already have dozens of tubes of different stuff aboard, most are at throw out stage with only a fraction being used and am trying to put a stop to that.
I bought the Lanox as it seems to be one product for 100 jobs and for the last 5 years, it has been.
Thoughts?
INOX-MX3 lubricant (LANOX-MX4 for the more extreme climatic condition areas) stops electrolysis between aluminium and stainless steel, keeps fibre optic cable connectors corrosion and moisture free
Use LANOX-MX4 to protect against moisture and corrosion, refrigeration unit circuits and cable connectors and plugs used in sea, road and rail containers, warehouse cold rooms and freezing works. Helps prevent short circuit arcing and earth leakage
Electrical
Switches, plugs, lights Use INOX-MX3 to penetrate corrosion and free up switches, bayonet and screw socket light globes, all light fittings, plugs and cable couplings, keeps this type of equipment corrosion free and in good
www.inoxmx.com
Electronics
Circuits, multi-pin plugs and keyboards INOX-MX3 frees up sticking computer and word processing equipment key board keys, keeps them free and in a smooth operating condition. Spray INOX-MX3 into multi-pin sockets and on multi-pin plugs
www.inoxmx.com
