100 Proof
"Please Lord, don't let me do something stupid."
- Feb 14, 2021
- 206
Hi All,
Forum FNG here. This is my first post.
I’ve been successfully using solar on my TT for many years. I mainly dry camp, sometimes for up to 2 weeks. I have a degree in engineering, know my way around electricity, and used to work for a domestic solar panel manufacturer. I’m just now getting up the LiFePo4 learning curve and have read a LOT on this forum and others. I’ve seen most of Will’s YouTube videos.
I’ve currently got a 12V set of 4 FLA GC-2s that are approaching end of life after 5+ years of faithful service. The bank has a nameplate capacity of 416 Ah. I’ve never had the bank get below 70% capacity. I’m looking to build a 12V 200 Ah LiFePo4 battery. I have a few questions:
1- I’ve read on a marine forum that it is not recommended to use cells greater than 200 Ah because,
“A sales manager at Sinopoly I was talking to was adamant about using 100Ah or 200Ah cells only for assembling marine battery banks, with 100Ah being preferred and 200Ah acceptable. Large cells simply don’t have the structural strength-to-weight ratio required to be taken to sea on board small crafts and would exhibit shortened life due to internal mechanical damage arising from on-going vessel motion. It is common sense: as a cell becomes larger, its internal weight increases much faster than the rigidity and surface area of the casing and the casing is all what holds the plates together in a prismatic cell.”
With the proliferation and popularity if 270+ Ah cells, is this cell failure mode being seen in non-stationary applications, or is it possibly too early to tell? I suspect that compression mounting will be key in the long run to manage this.
2- Given that in a solar application, the purpose of a battery bank is to carry loads when the sun isn’t shining, or the loads briefly exceed solar capacity, I want to set my charge controller up to carry loads during the day without discharging, or over charging, the battery. Given the extraordinary flat Voltage curve, and the fact that Voltage levels “settle” after charging, I’m struggling to wrap my head around the variety of charging profiles I’ve seen.
Is a consensus developing around how to deal with this? For those of you with a Morningstar TriStar MPPT-45, is the custom charge profile published by Morningstar adequate as is, or did you tweak it? BTW, I see that even Morningstar has published multiple profiles; one for Battle Born, and one for “generic”. I can’t wait to see how this turns out!
Cheers!
100 Proof
Cheers!
100 Proof
