Old_Skewler
Existing setup: 240V split phase 12kW Propane Generator wired to 240V split phase panel:
GEN >> (4) wires [L1, L2, Ground, Neutral] >> 240V Split Phase Panel >> Cabin
I am adding a Growatt DVM-MPV AIO Inverter and a 48V Battery to the system. The installation manual only mentions connecting the L1, L2 + Ground to the Inverter AC Input and from inverter only L1 & L2 back to the split-phase panel on AC Output. Per diagram below:
Could someone help with the following questions:
1. Is the Growatt wiring diagram correct or missing the ground and neutral wiring? It seems wrong to wire the NEUTRAL to the inverter AC Input when the inverter wiring diagrams does not show the neutral on the AC output. How does this work? I suspect I am missing somethin evident.
2. Do I leave the ground (bare wire) as it is in the existing panel? Or do I need to somehow wire it back to the inverter?
Thanks in advance!
Thanks in advance!
