plaidcabin
- May 3, 2021
- 28
edit: wrong forum. Where is the delete button?
Please forgive the sloppy paint work. Graphic design is not my strong suit!
6 335w Canadian Solar PVs will be roof mounted, I may add a 3rd mppt for vertical wall mounted winter panels at a later time. Cabin is intended for full time use, and should have thermostat controlled propane heat, with supplementary woodstove - so low temp is not as much of a concern.
Not pictured are the 5 Daly 8S 24V 100A BMS, 2 Epever Tracer MT 50's, and the 300A Shunt display.
All input is welcome, I am faking it til I make it here. Thanks for looking!
