Some MPPTs (e.g., Schneider/Morningstar) and inverters (e.g., Outback, Magnum) have adjustable low voltage cutoffs, why not just use one of them?
On all the controllers I looked at, that cutoff attached to the charge controller is intended for low amperage loads. Perhaps it could be used to control an on off switch to an inverter by putting a relay on it if the inverter was capable of remote on off. My SAMLEX inverter is.
On my Victron Equipment, it has an option for a low voltage relay in the software. Since I don’t see anything this relay would plug into, I assume that this would be powered by an accessory device operated off Bluetooth.
The charts i've seen show 12.2 as 50%. the only inverters i've found cut off at 10.5! FAR too low.
I'll look into it, and the LVC is adjustable so I can change it as I learn.
For measuring voltage to determine SOC, this may not be the best way to have a cutoff. I found that higher wattage devices that may be on for a few seconds or minutes will drag the battery voltage down temporarily, giving a false low state of charge.
THe reason the inverter has a 10.5 cutoff is when you’re maxing the 2000 watt inverter on a battery bank, you will experience voltage loss, which changes to heat, more so the thinner wires you have. I have 4/0 on my 2000 watt inverter and I set my alarm for a 60% SOC based off voltage, and the alarm would trip because the voltage would drop low when a 1000 watt device came on, but the SOC measured off my battery monitor that calculates AH used and the Puekert Effect said I still had 80%.
There’s no way around this voltage loss on higher wattage loads. You can get thicker wires, change to lithium batteries, and switch from a 12 volt system to a 24 volt system, and it will be less extreme, but the voltage loss is still there.
You can calculate that voltage loss here:
This free voltage drop calculator estimates the voltage drop of an electrical circuit based on the wire size, distance, and anticipated load current.
www.calculator.net
Start looking at 155 amp loads at 12 volts, which is close to 2000 watts. Use 6 AWG wire for a 10 foot run which is a realistic inverter to battery run. I say 6 AWG because really shady inverter manufacturers will include this with their inverters when you purchase that, and then move up to 2 AWG, then 2/0, and 4/0 and you’ll see this loss get less.
