EnoughToBeDangerous
- Jun 14, 2022
- 1
I've been contemplating making a 48v battery bank from Gen 1 or 2 Leaf batteries. The wiring is pretty straight forward, but what I'm not as familiar with is BMS and the battery chemistry. Seems that some don't use a BMS at all, and some use a 14S on each module bank. If you need a separate BMS on each module bank, that severely cuts into any cost savings of DIY. What is the consensus? Also, the modules I'm looking at are approx 50-65% capacity. Is there any information out there on approx cycles and calendar life remaining for modules that are at 50ish % capacity? Also, what's the safety like of the Leaf batteries? Haven't seen much concern with it, but I'm sure it's not as safe as LifePo. Thoughts? Thank you in advance
