You keep mentioning "engineering" and "engineers". Were those engineering documents provided by Chiko? If so, how revised were they by your local PE?
The Maximo is nowhere near what you show. The footers were 18" diameter columns leading down into 5' x 5' x 1' spread footers (smallest spec), buried 12" - 18" below grade. The anchor bolts in the engineering documents aren't J-bolts, but 1" diameter, 24" long galvanized steel (Hex Head ASTM F 1554 GR. 36 1, hef = 21.000 in). I ended up with Grade 105 because that is what was in stock. They are buried 21" deep in the concrete, followed by matching nuts and washers to create a base, then the base plate, then washers and nuts to tighten.
These aren't flush to the concrete pillars because the specs call for a standing plate which, last step, is to fill in with structural, non-shrink grout. The underneath nuts are used to make adjustments to the columns for level and plumb.
And, yes, that sort of squeezes down the space between the posts. Phenomenal cosmic solar power; itty, bitty, parking space!
