CCA is a fine alternative to aluminum wire. It meets all NEC codes, and as long as it is sized as ALUMINUM, not copper ampacity, it works great.Aluminum wire or copper wire. Just no copper clad aluminum wire. History has shown why that is a bad idea. Amazing that the idea has came back around after so many electrical fires were caused by CCA.
My condo was built in the early 80’s, 100% aluminum and CCA throughout. And aside from some Sheetrock issues, has been flawless…
Is it far more fragile when rewiring? Yup… best used as a one run, rip out if changes are needed.
Wire nuts cut through the copper plate, so, mucking about is unwise…
I actually did a walkthrough in a major CCA plant
