Craig1
Hi everyone,
TLDR: some cells have burst/deformed whilst not being used, connected as a 48V battery, any insight would be appreciated! (Pictures attached)
In 2022 I bought 48x LF280K 3.2V prismatic LiFePO4 cells with the aim of building 3x 48V batteries. Only one of these batteries is being used regularly and the other 2 I've been cycling every 6 months and then storing at roughly 50-60% SoC. To cycle the currently unused cells, I'll have one set of 16 cells setup as a 16S1P 48V battery and swap it with the main battery I'm currently using with my SPF5000es, drain the battery to a low SoC by either lowering the charge amperage or disabling the solar then charge it back to 100% SoC. Repeat that for a few cycles and then do the same with the remaining 16 cells. One of the spare batteries has been sitting connected with a JK BMS with 2A active balancing (i could be wrong but i believe its the B2A24S20P model) whilst the other 16 spare cells sit in their boxes.
After cycling half of the spare cells (the ones that i'd left connected as a 48V battery), i was disconnecting them and noticed some damage to about 4 of the cells (as seen in the pictures), one of which was particularly worrying. All the cells stored in the boxes were fine and this is the first time I've noticed any damage to any of the cells over the past few years. The worst one had also left a indent in the wood it was stored on indicating it might of ruptured with quite a bit of force. (Yes i know i'm getting rid of the wood, even though it was planned to be temporary, silly idea..)
If anyone has any insight on why this happened i'd be very grateful! I've probably missed some important information out so please let me know and i'll try fill in the gaps as best as possible.
Thanks in advance!
Thanks in advance!
