Suijkerbuijk
I cannot be held responsible for this information.
Reason that my battery are set in the boat space that the temp on the bms sit between 20/25 Celsius.Those are prismatic cells by the way.
And again, unless everyone is cycling their cells at optimal 25C, you'll have degradation well beyond the different between 0%-100% and 20%-80%. With LFP, what you really need to do to get optimal life cycle is temperature control. Cycle at 40C and watch it drop in half. Why is this important in this thread? Because it gets hot where OP is located.
The spot i have use is in the water 24/7 .
But away from the engine .
And in the winter i use heater in the boat (i life on the boat) so the temperature is always around the same time.
Same for my Victron inverter its on the same spot so operation temperatuur is really perfect .
Have the max output on my Victron.
