LFP cells gone bad
terrango
These are battery cells from my coworker. My coworker is a licensed electrician and insisted he knew what to do.
He decided that a BMS was not needed and that the inverter would take care of regulating and protecting the cells.
So he left the power on in the middle of winter, the batteries drained 100%, froze, then at some point the inverter charged 9/16 cells as 9 are extremely bloated.
And now the entire pack of 16 cells shows 6V. (100amp cells) 3 cells are holding a voltage of 1.02V, 4 other cells are holding voltages of .034, .056, .0455 and so on...
We sometimes learn hard expensive lessons.
He bought a new set of LFP batteries and has decided that the bms is still not needed.
he will instead just disconnect the batteries when not in use.
Dont do this..... Buy a BMS!
Your coworker is excluded from that statement.
He's a moron.
People like this are what cause the rest of us to have more regulation put upon us. The lobby for more regulation can point at cases like this fella that end up burning their house down.
Just when you think you have seen everything….
These are not AA batteries we are working with.
That is why I respect and appreciate this forum. Safe practices are taught and reinforced in our discussions.
A BMS is not needed. But some common sense is. If your system is running without a human present to check on it at least twice a day and has the capability of recharging the cells in cold weather then you've set yourself up for failure.
If you have cells that could be exposed to freezing temps you need to either get a BMS that has low temp protection/built in heating, install your own heating system with external temperature controllers or have a way to disable the charger/prevent the cells from receiving charging current if the temperature drops below a certain point.
I'd like to know how his cells dropped below 2 volts. What inverter was he using? Did he have it correctly programmed with a low voltage setting? I'm going to bet the answer to that is no.
More importantly, what drained his cells beyond the low voltage threshold of the inverter? What was drawing a load after the voltage in the pack was too low to power any kind of AC load? I'm assuming his inverter had completely powered off and there was no idle current draw from it...so??
There's a guy on another forum who built his own 8-cell LFP battery and despite my warnings he was set on not using a BMS. Instead he just hooked up a Heltec capacitive balancer. He's been using it for about 8 months now in his camp trailer, and posts updates on how it is doing. I guess it can be done successfully, at least for 8 months. ;)
I'm not sure I get why someone would specifically choose not to use a BMS. Except for some of the crazy expensive ones (Batrium, REC, etc.), they are not a significant cost relative to the whole system.
I know someone using NMC without a BMS (same PHEV cells I'm using with the Batrium). He is EXTREMELY knowledgeable, and is a bonafide inventor of some pretty impressive stuff. He has his own custom monitoring system in place, is using active balancers, and he doesn't go anywhere near 4.20V when charging (3.92V). He does have a pack voltage based cutoff relay system in place at 4.0V/cell average.
Each of his cells is capable of 150A (about 6C), and there are 21 cells in parallel. They are also internally fused (built into the Panasonic cell).
So, it's the next best thing to a BMS, but he's aware of the risks, is intimately familiar with the cells, and has made a conscious decision to not deploy an off-the-shelf BMS because he sees little added value over his own custom solution.
It's a little nuts, but he's the only human on the planet that I personally know, who I think is probably going to be fine.
Please keep us updated on the results over the next year.
Should be interesting if it can be held together.
Often third time is the charm ;)
You literally just expressed your lack of common sense.
A human BMS has a 100% failure rate.
Everything else you said is irrelevant.
A human BMS has a 100% failure rate? So the packs made in the early days of LiFeP04 for RV's that had no BMS and are just now being taken out of service in some cases (usually to upgrade to 304's or something similar) that never had a BMS on them and survived a decade or so are................
Like I said, if you have low/high voltage cutoff in your system (ie inverter and SCC) and you trust them because you know as long as you don't push them hard they have an extremely low failure rate you can run a pack for thousands of cycles without a BMS.
I have a small A123 12V 20Ah pack with no BMS and she's still chugging right along. Rarely ever take it below 12.8V and normally I'm using a Lipo balance charger to bring it back up to 13.6-14.0V. I'll let you know when it dies but don't hold your breath.
Quite the contradiction....in such a short span of time.
The point of the BMS is not the pack voltage, it's the cell voltages...
In your 20 amp hour pack, what are the cell voltages when the pack is at 14 volts? Any of the individual cells over 3.6 or 3.7 volts? it's the individual cell safety and health that is the point of using a BMS.
I have seen instances where a cells in a pack become unbalanced and the pack voltage of a 48V 16S pack, for example, might be 56.0V however you will see a cell at 3.6V and some at 3.4V. Moving from 3.6V to a higher voltage that can be cell damaging takes just a few seconds or less with enough charging amperage.
One could run without a BMS in theory, if you were to work very conservatively inside the knee areas of the LFP cells. However, over time, the imbalance between cells will increase, some cells might be at less than 3.0V while others at 3.6V and higher. An active cell balancer might help keep a loose balance. But there is nothing in place for a safeguard.
You'll have to provide evidence of this claim.
The only thing I'll grant you an exception for is the use of a balance charger as you indicate. That essentially eliminates the risk of cell over-volt during charge, and it minimizes risk on the downside as at least you know the battery is top balanced with max potential capacity at every charge.
Not in the least. I responded to your, "A BMS is not needed," which remains an absolutely absurd statement vs. me summarizing a custom monitoring system by someone with high technical knowledge and understanding of the consequences. These are also a chemistry with voltage to SoC correlation unlike LFP.
It's likely you've not been around long enough, and/or you've not paid enough attention to see the many instances of destroyed cells from folks deciding to run without a BMS. One guy completely trashed a Tesla module from overcharge and is lucky to not have experienced a fire.
So it's probably best to keep your BS statements to yourself. A BMS is needed.
3.6V max. Use a lipo balance charger, don’t always use the balance function. It’s an A123 pack that was barely ever cycled. Worst I’ve seen the cells is 14mV when one hit 3.60. The others weren’t too far behind.
Edit. Oh you were asking at 14V. 3.50V with typically an 8mV deviation
"A BMS is not needed" (but I'll let you know later that I use a balance charger)
A balance charger is not a regular piece of equipment for most on this forum, and it's a very different thing. Even if you don't use the balance function, they still charge based on set per-cell limits. If you can see the cell voltages, the balance leads are connected, and it's regulating the charge based on the peak cell voltage, not pack voltage.
When you balance charge, it top balances, and there's not an inverter/charger or MPPT that will do that for you at the cell level, so it's 100% irrelevant to a "DIY Solar Forum," and "A BMS is not needed" is just irresponsible diarrhea of the mouth.
@MarcoWasRightIsWrong
The legend continues he is now on the forums:
From what i have been told, he was using a Growatt 3k unit. He said all the settings were set properly. At first he blamed the inverter as faulty. I took it home and tested it and it worked fine. I checked his settings and it was configured correctly.
My coworker went on to say that there was 2 ft of snow on the panels all winter and a battery blanket was always drawing power to keep the batteries warm. So i figure he drained the batteries completely, they froze at some point and were probably overcharged at some point.
The pack voltage (16 cells) registered 5.67V total.
We did some testing here at work and 13/16 cells are done. wont hold any charge. The remaining 3 cells will take about 1V each, but after 24 hrs the voltage sits at 0.45v.
So he has a new set up batteries now and decided after 3 weeks of the system running on its own (unattented) to finally put the bms in. Bms was installed June 4 and cells 1-12 were 3.3-3.4V, Cell 13, 15 were at 2.2V, Cell 14 and 16 were at 4.51V and 4.25V and bloated.
So he has decided to use AGM batteries because he states they are more reliable then Lithium lol.
did you test the 13 for capacity, internal resistance and self-discharge? if the answer is "no" to any, you don't know they're good.
