Glock24
Hello everyone!
I got 5 LG EM048126P3BA 6.5KWh 48V modules for really cheap. They all work but I have no way to communicate with the onboard BMS to check cell voltages and balance them if needed. Because of this I decided to get a new BMS and my choice was the JK BMS JK-BD6A17S8P as the max charge/discharge current for these modules (according to spec sheet) is 60A and they have a 2p14s configuration.
I ordered 2 units and they arrived surprisingly fast. I got one out and made a temporary test connection to one of the battery modules. I used the connector for the factory BMS thanks to the pin layout I found here:
secondlifestorage.com
Of course I verified voltage on each pin before connecting the BMS. Once everything was connected I pressed the button and it came to life!
As I feared, the cells were not balanced. Most cells were within 10mV but the lowest one was 35mV lower than the highest one.
After leaving it balancing overnight the voltages are more close, bit still20mV difference.
So far the balancing has been going with the battery disconnected, would it be faster while the battery is charging?
It seems this BMS works OK, I think I'll order one for each module.
BMS in LG CHEM ESS modules
I've just my personal measurements and drawings, but I can send it to you.
