LG MNC battery BMS
HaldorEE
I just bought 7 of these LG 120AH battery modules to make a 25.9V battery for my van.
Question is what is the best BMS to use with these batteries. My thinking is to get either a 150A or 200A Daly 3.7V, 24V, BMS. Question is which one?
What do you guys think?
Did you eventually solve this? I have the same batteries
I bought the 150A Daly.
However I finally decided to not risk using the LiNMC cells in my RV application. I bought a set of the EVE 280 AH LiFePO4 cells and built an 8S battery pack out of them. Double the WH for close to the same price per WH. I think I will put together a portable power station with the LG cells plus an inexpensive low frequency inverter/charger. This one looks likely.
