EnergySolutions
- Jan 14, 2020
- 11
Price: $195
Condition: Lightly used, under 35 cycles ( professionally tested)
Manufacturer: Ninebot
Enclosure: Hard plastic and metal hybrid case.
Cell holders: Sturdy, custom hard plastic cell holders with anti-vibration and insulating gray caulk
Connector: Custom Segway-Ninebot connector
BMS: Custom Ninebot BMS. LOCKED. Needs flashing or re-installment of a new one that's non-proprietary.
Capacity: 27900mAh 1004wh
Voltage: 36v (max voltage 44v min voltage 30v)
Discharge rate: 90 amps, 135 peak (1000w continuous, 1500w peak)
Charge rate: 6 amps
Charge time: 6 hours
Cycle life: ~800-1200 full charge and discharge cycles (gentle use) or 500-800 cycles if used regularly
Amount of cells: 90
Configuration: 10 series 9 paralel
Cell manufacturer: LG
Cell model: lg18650mh1
Cell chemistry: Lithium-ion
Cell capacity: 3200mAh
Cell connection: 0.2mm pure nickel strips
---Weight---
Without enclosure: 11 lb 4 oz
With enclosure: 12.5 lb
---Dimensions---
Without enclosure: 14.5 inch x 4 inch x 2.8 inch
With enclosure: 16.7 inch x 4.7 inch by 3 inch
Battery meter and charge port are installed in the enclosure.
Does not come with a charger.
Charge rate: 6 amps
Amount of cells: 90
---Weight---
---Dimensions---
