Galaxywide
- Apr 27, 2022
- 2
Hello! First I'd like to apologize if this is in the wrong spot, and while I know it's not the primary focus of the forum this seems to be the only place I've found good discussion on battery tech.
I'm looking to replace the batteries in my APC SUA3000R2X145 which uses 4S2P 5.5AH SLA batteries, and while I could just pick up some SLA replacements I figured "it's 2022, surely there must be a better way!" After some reading, I was looking into lifepo4 packs and cells, which seem ideally suited to 12v replacement, but appear to be significantly more than I was looking to spend (this is just a hobby, nothing critical nor something I can justify $600 worth of batteries on).
Then I stumbled on these Panasonic 48V Power Modules, which seem like a great option and cheap to boot. I'm thinking of combining them with DALY 13S 48V 50A Li-ion BMSs, and using a total of 2 modules and 2 BMSs in parallel to get the capacity I want. I know the BMSs are undersized for the modules, but given that the UPS can only pull ~56A in total and I'll have them in 2P, I don't think I'll ever get close to the full 100A (realistically this UPS will have MAYBE 500W coming out of of it, unless electricity suddenly becomes free {I realize the irony of that comment on a solar forum, it's something I'd like to look into someday!} and I get a LOT more servers).
Is there anything that I'm missing here, or any reason what I want to do isn't possible (or advised)? I believe I can edit the charge parameters of the UPS via serial based on some posts I've found, which should make it play nice with the different voltage and added capacity.
Thanks, this seems like a great forum!
