We have the Li-Time 40Amp DC/DC charger. After the charge cycle is completed - 14.6V, the charger continues to apply a constant voltage of 14.6V This is what their charge graph implies. We confirmed with a DVM on the output. Not what I expected to see with this charger. Would rather see the charger terminate voltage upon completion. The specs on the charger are titled, "Charging Voltage Limits" We reached out to LI-Time, and here's the core of their response:
"LFP batteries have high chemical stability and are able to safely maintain voltage at full charge without the need to maintain voltage through float charging. Therefore, LFP batteries do not require a float charging process like lead-acid batteries because they have been designed and managed with a balance of safety and performance in mind. It has been technically confirmed that the charger is a constant voltage output and maintaining 14.6V after charging has no effect on the battery."
We are going to charge up our LFP battery again to confirm there is no current flowing into the battery after charge cycle is complete. Seems Li-Time needs a tech editor to avoid confusion.
Welcome any thoughts on this.
