Ceefiveceefive
- Sep 28, 2019
- 94
Greetings!
What is Will's current LiFePo battery recommendation for folks on a budget?
Greetings!
Thank you! I will be building my own at a later date. I am just looking for plug&play right now & do not want to shell out a grand for Battleborns.Cheapest will be building your own if you are comfortable with that, and willing to put the time and research in to learn what you need to do to protect your investment.
Beyond that, I know that the costco deal can be good when it comes around (Lion energy for $700 or $750 I think?), there are a bunch of other cheaper lifepo4 around 100Ah, not sure what is recommended. I suppose the best way to check what budget options Will specifically recommends is checking his website and latest videos.
I know he has recommended some in the past but have not kept up lately for changes, hence my query to you all!
I believe @Will Prowse keeps the DIY Blueprints section updated with the "safest" deals that he recommends.Would be a cool idea for people in the know, regarding drop-in lithium batteries to keep a running thread with the latest community recommended deals, maybe there is already a thread like that started. Not something I've looked into.
I recently purchased two SOK 100 Ah batteries...haven't fully tested the battery, but the capacity test appears to be good (1300 watts each on initial test). I haven't conducted a full Current Load test to see how hard I can pull amps out. Charging seems to be good with 40amps going in, but I'm using an EPEVER 40A, and the SOK recommends 50A charging. I just received a 50A/60A charge controller today, and will test tomorrow on the SOKs. I believe Amazon just raised the price to $640, so going to the SOK site or eBay is probably the best price. SOK I believe will not charge tax (depending on where it is delivered). I'm not saying that these batteries will beat others, just letting folks know what I'm doing, and will let you know if I run into issues. So far no issues. I doubt I'll do a teardown (for now) since these are perfectly good LiFePo4. I've seen the YouTube teardown review, and am satisfied with the construction and configuration. I also have seen a YouTuber change two old SLAs for two SOKs, and the SOKs seem to be operating sufficiently.
Just replying to each Thread...not entirely sure how this forum works, but give me enough time I'll figure it out. Also, I can assure you nobody is paying me any fees, not sure how that stuff works. Also, SOK wasn't my first round of trials, I went with RockPal and Miady (see pics) prior to SOK. The Miady batteries are being built to provide portable low-cost power. I can assure you Miady (or Amazon) isn't paying me to build these battery packs with cases from Harbor Freight (<$12 with a 20% off coupon in August). Basically, I've spent hundreds of my money searching for the proper solar/battery fit/solution. I'm building a shed and want to power it with solar. I'm a smalltime solar nut with a bigtime passion, and the resources to do it...so I don't need anyone's money. Also, FYI, that 50A/60A charge controller, I mentioned earlier, is being returned (see pic) back to Amazon. Not that it doesn't work, but it is too noisy (fan) for my needs. I prefer the EPEVER 40, and will probably order the 60A version Commander (Renogy).Jeeez
You made like 5 almost identical posts about SOK batteries spamming the forum today.
How much are they paying you???
I believe it is 12.8v...I can see how 12.8v can be viewed as 12.6....attached is a closer view of the batteries.My question is: How did they make them 12.6v? Its painted on the side of the battery in one of the pictures?
Looks kind of suspect to me. Did they really misspell their email address on the battery? www.sokbattery.com vs sales@sokbatery.com Notice the missing "T" The certificate is only good for a total of 3 months. The only time I have seen that prior was on scam sites. (I was a PKI admin for a large multinational) The misspelling on the battery itself would keep me at arms length though.
Are they using bad cells to get 12.8v instead of 13.6 with most LIFEPO4 batts?
While your other concerns are legit, this last one is not. Lifepo4 cells are 3.2V nominal, 3.2v x 4 =12.8v, referring to a 4 cell ('12v') Lifepo4 battery as 12.8v is quite common (for instance Victron labels their batteries the same way)
12V 100Ah LFP $460 plus tax lowest price leader.I believe it is 12.8v...I can see how 12.8v can be viewed as 12.6....attached is a closer view of the batteries.
I saw this one a couple of weeks back, and it doesn't look bad. While it is cheaper...I was hesitant to try it out. One of the drawbacks is the discharge current of 20A, which can be good for some applications...I just don't have an application for it. I'll eventually need discharge of 50A or better for my new shed. At the moment I'm looking at a KiloVault battery which has 150A max continuous discharge, with a max charge of 150A as well. Pretty versatile, but pricey.12V 100Ah LFP $460 plus tax lowest price leader.
Product Description said:5.Max continuous charge current: 1C
6.Max continuous discharge current: 1C
