LifePO4 24 volt
Medora
Parry Sound
I just installed a new LifePO4 24 volt server rack battery, have everything set up with the MT 50 from the retailer and always get a Rated Vol error, day or night, the retailer says I should check the DC voltage coming in from the PV, but I get this error at 1:30 am when the PV is not putting any voltage out, our charge controller is a epever tracer 8420an rated for 48 volts and 80 amps and the inverter is a Microgreen 24 volt inverter/charger 24 volts input and 120 volts AC output, never had this problem with flooded lead acid batteries run in series.
Any help would be appreciated
