Yurtdweller
I have a LiFePo4 bank with 4s4p.
I have four 12v packs, each with it's own BMS. The packs are keeping good balance, individually. Each pack is wired to a Victron Lynx PowerIn busbar, with each pack having it's own megafuse.
The problem is that the packs are drifting out of balance from each other. This is because I have programmed my charge controller to stop charging at a voltage lower than the individual BMSs cut off charging. I did this just so that the mofs don't have to do the work of turning off charging.
Of course, this means that if one pack's wiring has more resistance, for whatever reason(chasing this issue), it will never get as much juice, thus will constantly fall farther behind.
Now, I'm going to balance them up by changing my cc settings so that the BMSs handle the top off(if the sun ever comes back), but I'm wondering what sort of active balancer, or whatever, I can install to keep the four seperate packs in balance?
Or should I just let the individual BMSs handle the charging control? I've heard that one should minimize how often the mofs have to activate.
I also wonder if I could simply install another 4 cell BMS to balance the four packs?
It seems the most logical, but that almost seems too easy? I'm guessing that the amp rating of the balance circuit would be too small for the job.
Or a 16 cell balancer?
I'm going to switch everything to 48 volts eventually, but my 12v 2kw inverter is all I need right now, and I don't want to swap everything over until/unless it dies, because I also have a lot of 12v appliances.
