eabyrd
SLA is a catchall term for AGM (absorbent Glass Mat) or Gel batteries. Neither require equalization in the way of a “wet cell” batterie. And yes lithium cells are often equalized as they approach top (or bottom) of their voltage rangesAre you saying your SLA is a Sealed Flooded Lead Acid. A 'sloshy'?
I am certain that acid stratification is a real thing. How do you stir the acid solution?
The other definition for equalization is when you believe the cells of your lead have become unbalanced. This is when you rely on a longer timed eq period at extra high Voltage. Some cells are deliberately overcharged in order to restore the weaker cells.
