So I've got 2 chinese LiFePO4 batteries in our van. Specifically 2x 100Ah LiFePo4 EWT batteries connected in parallel, made with ifr26650 cells.
It seems they will not charge above 13.25v anymore. I did over discharge them 2 times below 10v. The BMS has a low voltage cut off of 8v. I did not realize it was configured this low when I bought them initially I was a bit more of a noob then I am now. I am unsure what voltage they got to.
Typically I meticulously checking the voltage but I mistakenly left our inverter on over some cloudy days and ran the power down in the middle of the night.
I have also noticed in my victron charge history that the batteries would have a low voltage of 0-8v every day but I knew that the batteries were not dead, each morning we still had power. I connected to the charger from my phone and watched for about 10 minutes and found that sometimes when the charging voltage peaked at 14.6v it would trigger the BMS to go into a protective state and disconnect the batteries for a moment. When this happened the voltage would drop down to 0-8v for a few seconds before reconnecting and resuming charging.
I changed our charge parameters to be 14.2v and this stopped happening. I never seem to get above 13.5v charging no matter what anymore. Earlier I disabled the charger and it was at 13.4v. Almost immediately it dropped down to 13.26v. There was a light load on the batteries but it seems they are never getting fully charged, float hasn't been reached in days. I also read that balancing doesn't happen unless 13.6v is reached and it never seems to make it there.
What can I do to remedy this? Are they shot? Should I try to discharge the 2 batteries completely and then charge them up individually, then reconnect them?
I have a 5.5A wall charger for LiFePO4 batteries. I have a multimeter and I have a battery monitor that I could use to check capacity.
I have two other 100Ah LiFePO4 which are new that I'd like to parallel together and create a 400Ah bank if these are not damaged. I've only really been using them for the past 2 months and until the past 4 weeks they have not been discharged below 20%.
