Hello everyone,
I'm Vincenzo and I'm writing about lifepo4 parallel connection.
I have to build a battery pack 16s.
Now I'm using 16s 280AH in my system, it is new 1 year old and 150 cycle life.
I'm would like to rebuild and use 2 pack in siries: I would like to use 8S2P 280AH in series with 8S2P 260AH everything under a single BMS 16s with active balancer.
I tested the whole 32 batteries, internal resistance is similar and also discharge curve is similar until 3V discharge after that there is a 20amp of different capacity between 2 pack.
Do you think can i use this configuration? Thanks for any answer. ?
