SignatureSolarJames
Try Solar, the Grid will always take you back
NFPA 855 https://www.nfpa.org/codes-and-stan...s/list-of-codes-and-standards/detail?code=855
One thing about ESS systems that is often overlooked is the requirement to keep flammable materials over 4ft away in all directions.
It's not as much about the batteries catching fire (very unlikely and over-protected with redundant measures) as it is about the flammables around it catching fire, e.g. a floor or wood rack catches fire because a wire connection was not torqued with a torque wrench.
If you put enough heat on a LIFEPO4 Pack it will vent gas out of the cells, that gas will light like propane if enough is vented, then you will have to wait as your whole bank burns down. the BMS protections handle internal fires, not external.
This is very unlikely and most people with flammable materials will likely get away scot-free, but regulations are there to make things truly fail-safe.
Hardie Backer and steel are cheap, homes can be pricey.
