Sipma02
- May 27, 2020
- 141
I have qty 4, 7 watt heating pads (for a total of 28 watts) on my qty 4 280ah cells, with a 1/16 in steel plate for dissipation. Knowing what I know now, I would have used a thicker aluminum plate. Aluminum dissipates heat better. They have 1/2 to 3/4 of XPS foam insulation on each side, except the top. I'm seeing about a 25-30F raise in temp (compared to ambient) at the top of my cells, which I assume to be the coolest part. The bottom of my cells, where the heating plate is, sees about a 40F rise from ambient. I think you will have more than enough heat—perhaps too much. You could easily modulate the heat with a repeat cycle timer, its basically a little circuit board that you can set to 10 sec on, 10 sec off, 10 sec on, etc. You can set the delay to whatever you want. I found one on Amazon for around $10, but ended up not needing it because my heating pads are small enough that they dont raise the temp too much.Well, that heat pad is only a 150w, so far, I'm not too concerned (if it were the 500w version maybe I might)... Also the consensus from other forum members was that directly applied to a battery case could be a little hot, but mounted on the bottom-side of an aluminum plate (with aluminum having fast heat transfer properties) will dissipate out that heat across the plate quickly. Also the heat pad is only 5" x 5" square, where the aluminum plate is large enough for the entire bank to rest on.
So I am building 3 of these. The 12v (8x cells) bank has a bottom-plate of approximately 11" x 16" and my 2 other 48v (16x cells each) banks will have bottom-plate of approximately 23" x 16""
All three will use the same size 5" x 5" heat pad. I will likely do some testing and monitoring with it in the beginning... Hopefully I will even get it all together before Spring, otherwise will have to wait til next Winter to see it in action.
I will for sure test the bottom plate temp and see what it has the ability to push up to for temp without any batteries sitting on it first.
When I had it connected and not touching the batteries, the plate got hot to the touch—it would almost burn me. But once the cells were in direct, firm contact with the heating plate—it now doesnt get over about 70ºF.
