Engineer DIY
- Dec 31, 2020
- 9
Hello all, generally if a LIFEPO4 BMS has an option for configuring cell voltage levels to whatever even in the range of LTO cell 1.9V - 2.8V.
Then is it suffice to say that the BMS is compatible with LTO cells? Basically I came across a Lifepo4 BMS from company called Seplos and the general aesthetics of the BMS are well suited to fit in our existing telecom battery pack, so I am trying to understand if I can use the same BMS for LTO cells as I haven't found LTO BMS with the same shape and appearance. The company said it's compatible with Lifepo4 and the cell voltages are customisable.
24/48V 8S/16S 150A lithium iron phosphate lifepo4 bms monitoring system battery management system with LCD Screen
High quality 24/48V 8S/16S 150A lithium iron phosphate lifepo4 bms monitoring system battery management system with LCD Screen from China, China's leading Seplos Smart BMS product market, With strict quality control Seplos Smart BMS factories, Producing high quality 24/48V 8S/16S 150A lithium...
www.seplos.com
