I wonder how that spray on truck bed liner might work to coat the inside of a metal box. I have no experience with it, just wondering.I strongly suggest a non-conductive layer between the actual LFP cells and the case if you make a metal one jus in case anything goes amiss. Standard steel would need to be painted as the last thing you want is rust, stainless or aluminium would be better.
Is this lithium iron phosphate battery? It looks small.Does anyone make a case for 16 150Ah prismatic LiFePo4 ??
Boss said I could use the steel from a cracked rectangular diesel tank ... free metal but I need to drain it and purge the fumes with Argon before cuttingI wonder how that spray on truck bed liner might work to coat the inside of a metal box. I have no experience with it, just wondering.
All three packs are LiFePo4 .... two 38120's -- 4s2p and the larger with DIY 1/4" aluminum buss bar 4s8p .... the blue pack on the floor is the prismatic 4s4pIs this lithium iron phosphate battery? It looks small.
It looks good. What's their power and their price? Sorry, I have a lot of questionsAll three packs are LiFePo4 .... two 38120's -- 4s2p and the larger with DIY 1/4" aluminum buss bar 4s8p .... the blue pack on the floor is the prismatic 4s4p
Do you have a link ?You may find something like this insteresting. You can buy them in Aliexpress.
Have a look here for High quality connectors: Make sure you get 3/8" studs !I need to either notch out a spot for the cables to pass through or get some bolt on pass through....
