Hi all,
I've received cells, they are CATL 86Ah, i only tested 2 for the time being and they both show the same behavior :
- Using 3.65V and limiting my charger to 12A, charge current do not exceed 10A when cell is near empty (2.5V) and near 7.2A when cell is 3.2V.
- I used a capacity tester, parameter are : 100W discharge, cut voltage 2.5V : click on ... power is somethin like 40W..
My question is : appart from a bad conenction, would a defective cell (that would be 2 cells) or old cell would show this behavior ?
Tommorow i will clean contacts and try again but i'm pretty sure it's not a problem.
