Sent you a messageno i can ship. what is you address and ill get you a price.
1 | Nominal Voltage | 3.2V |
2 | Nominal Capacity | 105Ah |
3 | Standard Charge Current | 21A (0.2C rate) |
4 | Max. Charge Current | 105A (1C rate) |
5 | Continuous Discharge current | 2C (210A) |
6 | Peak Discharge Current | 3C(315A) |
7 | Charge Cut-off Voltage | 3.9V |
8 | Discharge Cut-off Voltage | 2.0V |
9 | Inner Resistance (Impedance) | ≤ 1mΩ (At 0.2C rate, 2.0V cut-off) |
10 | Weight | 2Kg |
11 | Dimensions | Length: 200.5mm Width: 130.3mm Thickness: 36.7mm |
12 | Operating Temperature | Charging: 0°C ~ 45°C Discharging: -20°C ~ 60°C (The cell surface temperature cannot exceed 70°C) |
13 | Storage Temperature/Humidity | Temperature: -10°C ~ +35°C Humidity:65%±20%RH (optimal store temperature of 23 ± 5°C for long term storage) |
