Pickuptrck
NV owner builder
Hello. Relatively new to The forum but not necessarily new to solar, just LFP batteries. I've gone through many of Will's YouTube videos, and I found a few disparities on recommended charging profiles and wanted to set the record straight.
YouTube MPP inverter video 1:
C4 (bulk) 58v
Fl4 (float) 57v
Big battery modules (possibly li-ion??)
YouTube MPP inverter video 2:
C4 (bulk) 56.4v
Fl4 (float) 55v
Battleborn modules
Which is right? Both appear to be using lfp batteries and inverters from the same company, though different models.
My main concern is with about 30-50a avg typical of charge, at night my battery resting voltage is around 52.5 to 53.2. The inverter has shut off a couple of times (48v) with an extremely small load of some RV lights and an RV fridge. I would like to boost the power and have intentions on tripling the battery size from 13 kW to close to 40 when the house is built later this year
My system:
16s 280ah raw cells /13kw
Dally BMS 200a charge 100a load, non-bluetooth
MPP LV6048
3s3p 355w JA solar in PV1 about 5yrs old
3s4p 260w REC into PV2 about 7yrs old
Fully off-grid.
Future plans (about 8 months)
20kw of 400w panels, full swap of current panels
26kw more battery
additional LV6048 in parallel/12kw total
240v 9kw backup generator
Full house load calc may change some of the above, working on picking appliances in March.
C4 (bulk) 58v
Fl4 (float) 57v
C4 (bulk) 56.4v
Fl4 (float) 55v
Battleborn modules
My system:
MPP LV6048
Fully off-grid.
26kw more battery
